I have the Mac 26, 2 years old. It's a good boat.
QUESTIONS: The two black stripes on the upper hull are fading, getting a white chalky look to them.
Is that chalkiness Oxidation ITSELF, the black part; or is it oxidation from the white above, that's running down onto the black? (Because it'll affect what method I use to clean it off.)
To clean, do you recommend a buffer, like McGuires, slight grit, then a polishing compound? Or just something like Barkeeper's Friend http://www.barkeepersfriend.com/
Or Windex and Pledge?
I note that the black striping below the rubber line (lower hull) is still perfect. That's why I was wondering if it was run-down from the white above.
I'm worried that if I use a (small grit) cleaning compound, even freom a good company like McGuires, that it'll scratch it. But then I wonder if it's a good idea to use NU FINISH to make it pretty again.
Thank you'
