How viable do you think it might be to simply bend the old mounts out 3/8"?
Yes, but... those ladder arms have a radius bend that won't allow it to lift up into a vertical position, just slightly above horizontal at best. Also looks like it's proximity to the rudder bracket would interfere with rudder motion - use quick pins to install / remove it.The holes won't be parallel anymore. I'd have to bend...
Well, I see a few problems with that off the top of my head:yukonbob wrote:Why not leave the brackets in place; manufacture a bar that will span the two brackets and mount the ladder off that.
True. The mount points that come with the ladder allow a more full range of motion.K9Kampers wrote: Yes, but... those ladder arms have a radius bend that won't allow it to lift up into a vertical position, just slightly above horizontal at best. Also looks like it's proximity to the rudder bracket would interfere with rudder motion - use quick pins to install / remove it.
