Stoneguard
Gater Dunn
Location: Victoria B.C. Canada N48º25.506 W123º18.178 OakBay Marina
Stoneguard
Post by Gater Dunn »
any cons for using stoneguard under fenders
yukonbob
Re: Stoneguard
Post by yukonbob »
Like a truck bed liner? I've been using sailkote this year under the fenders, really cuts down the squeaking and I assume the chafing
Gater Dunn
Re: Stoneguard
No I mean the trailer fenders
I just replaced my axle with two axles now have to put on new double fenders they are steel and after under coat and top coat I was wondering if spray on stone guard or like rubberized coat on the underside would help fight rust or cause more problems
yukonbob
Re: Stoneguard
Post by yukonbob »
:D :D :D My misunderstanding.
I'd go for it. That stuff is pretty bomb proof. That or truck bed liner should do the same thing, although I did some a few weeks ago (can't remember the brand). Looks good but the dogs nails are taking it off in layers. Really hard with no give, nothing like quality bed liner spray.
raycarlson
Re: Stoneguard
Post by raycarlson »
Don't use steel, and if you do don't spray stonegaurd on them youll increase corrosion, use aluminum or fiberglass fenders and save yourself the troubles.
Re: Stoneguard
My steel fenders are original 1999 issue, and still fine, with nothing but black paint on them.
But it's never seen salt water. :wink:
mrron_tx
Re: Stoneguard
Post by mrron_tx »
LOL... No salt water helps alright :D I would spray them top and bottom ,just to make sure :wink: Ron.
