Can anyone tell me if the ETEC-70 motor can be fitted safely to a 2013,
This has probably been ask and answered in the past but I'm looking for something a little more contemporary
seahouse wrote:Steve and Deb -
I have yet to hear from anyone who has a counterpoint to this, but my assessment of the transom integrity is that it will easily take much larger engines than have been installed on any Mac I've seen here to date.
The transom walls are thick, laminated, reinforced by glasswork, and are closely supported by the walls and shape of the adjacent well. Confirm this for yourself by standing on the motor cavitation plate and bouncing with your body weight, while observing the flexing that happens in the transom. You should see none.![]()
Having said that, in an older boat where motor mounting has not been properly done and water infiltration has taken place, you might encounter a punky transom in need of reinforcing, but even for a stock motor.
Transom strength is one of the common considerations (there are several others, of course) when overpowering a boat (I've done this myself to power boats in the past, but have reinforced the transom in each case) but is not a concern on a Mac M, (nor on an X, as others here might say, but I have no first hand experience with them).
I went with the 60 for the simple reason that it was the largest that could be mounted and still maintain the warrantee of the boat.
It's good to be continuously aware of potential stability and handling issues when mounting a larger than recommended engine to a boat, but those are also the same issues to be conscious of no matter what engine is mounted on the back.
- Brian.
Question on the wedges: Sea Wind are you happy with the performance without a wedge? I have seen some comments that the wedges are required for the M but not the X and I want to understand exactly what they do and why. I am planning to go for the ETEC90 in the spring and am not sure if I want wedges or not. Did you add any reinforcements or plates to distribute the load on the transom?Sea Wind wrote:My 2013 Suzuki 90 was installed by a dealer in my 2001 X. I have a standard 3 year warranty. No wedges were used/recommended. This is a well-known dealer that specializes in selling and repowering California skiffs, it is also one of the few Suzuki dealers in the eastern shore of the Chesapeake bay. They mentioned that our boats have very strong transoms and if the boat is abused with these engines (i.e. pounding hard on waves), he expects that the hull will be damaged before the transom. They took away the old Tohatsu 90, installed and rerouted the new cables and controls.
