I've read the lightning thread and resisted comment, but every so often this comes up again. The Univ. of Fla has studied lightning, Florida, especially the central part being one of the most likely places in the US to be hit. Google lightning & Uof F.
NASA has studied it here too, they also have good cause for concern with the Cape nearby.
Lightning strikes, deaths and injuries are a regular occurrance here.
In florida. lightning has "...15 to 30 strikes to ground per square kilometer annually and Nevada only a few strikes per square kilometer annually.
Lightning article
Lightning killed 2 people within 5 miles of my home last year, on the ICW. They had beached their center console on an island and sought shelter from a storm under a tree because the boat ramp was clogged with all of the boaters rushing to get off the water at the same time.
Had they simply not stood under a 35 foot tall Australian Pine tree and stayed in their vessel as part of the family did, they might have survived. There is no way I'm buying that anyone on our dinky little sailboats can add wires or jumper cables and "direct" or "channel" a 100 million volt lightning bolt that dissipates 600,000 degrees F. of heat energy, when it can turn air into a conductor. Building protection is not the same as boat protection, IMHO.
If you have a building with 54 copper rods buried 6 feet deep wired to a heavy conductor lightning grounding system, than you probably do have a good chance of survival. Just don't take a shower during the storm because lightning does pretty much what it wants to, and will follow plumbing and wiring long distances . That's one thing. But I'm against doing anything that would make a better ionization path between earth ground, my tiny boat, and God's right hand. He can take me when He wants me back but I'm not gonna make it any easier for him than it needs to be.
You might be better off just dropping the mast.
