Same here, with our '03 Odyssey.March wrote:I did tow the MAC with a Chrysler van for years. <snip>
1) the van seemed much more stable than the SUV. It also used a little less gas on the highway. Never had a problem pulling the Mac out of the water with a front-wheel drive.
See above.March wrote:4) I had a Honda Oddysey whose towing abilities were right on the line, but it didn't have a hitch. I replaced it with the Nissan, but my guess is, the Oddyssey (or even better--a Toyota Sierra) would have worked just fine with the Mac. There are a few people on the board that have used Sierras and their comments are quite positive. I, for one, believe them.
I believe it's the long wheelbase and wide track that makes the difference. Pickup trucks may have higher load carrying capacity, and a full frame, but again, in my opinion at least, long and wide beats short and narrow, and pickups and vans are longer and wider than mid-size SUVs.March wrote:5) THe SUV is a compact, sturdy beast of burden, but it's less stable than the minivan which hugs the ground more efficiently, I guess. Not such a big deal if you pay attention to the weight of the tongue and you're n ot in a hurry though.
My Highlander isn't as stable on the highway as the Odyssey, but it has a factory tow package and 5 kip capacity, with tranny cooler and better engine cooling (bigger fan I believe is the only difference), which is why I got it. The Odyssey had no trouble pulling the boat out, even with ballast, though I open the vent and drain just before hitting the trailer, so any bow-high attitude starts draining ballast, which shortens ballast draining time.
Much as I'd like a PU for trailer towing, a larger SUV is probably the way to go for me. Something like a Suburban, Excursion, or Sequoia (7400 lb tow capacity, 68/69" track, 122" wheelbase, last two dims a bit larger than the Odyssey, and much larger than the Highlander, and tow cap. of 3500 lb for the Odyssey, 5000 lb for the Highlander).
I got for this job tows like a dream; also chugs gas like a champ
