1. Possible window leak over port galley window. Have found water in top exposed cups and glasses stored in teak galley racks after rain.
2. During rough motor passage with spray over the bow, found major water in the bilge portside (2 inches). Wonder if I have ruptured the seal between the deck top and hull, especially close to the bow and water entering when going to weather. When activated bilge pump was able to pump dry, so not a hull breach or would have continual flow of water while boat in the water.
This last rain produced no water in the bilges, so suspect the window not the cause. Water in port side bilge only noticed after rough motor passage or rain.
QUESTION:
Have anyone else experienced similar experience? How did you locate source of water? What repair procedures do you recommend?
