Q1
Boblee wrote:The standard couplings are a mongrel set up and technically illegal here and unless you need a breakaway system it's much better to convert to these, http://www.ebay.com.au/itm/Override-Cou ... 549wt_1040 or are these illegal over there?
Mongrel issuesDivecoz wrote:I too on occasion had issues with the " Key " but with the 5 wire hook up I no longer have those issues.. I will ask what is the Mongrel issue?
The Unit you show looks to be a DIY garage shop nightmare.. The issue is to apply brakes on the trailer when the tow vehicel is stopping and THEN to allow backing up without applying the brakes..Boblee wrote:The standard couplings are a mongrel set up and technically illegal here and unless you need a breakaway system it's much better to convert to these, http://www.ebay.com.au/itm/Override-Cou ... 549wt_1040 or are these illegal over there?
I added...Highlander wrote:I always block my trl whl's it's a good theft deterent !!![]()
Highlander wrote:Sometimes I block the whls back-up to activate the brakes & then install the lock -out & that locks the brakes on just like a parking brake ,
One time I forgot I done this , pulled the wheels off thinking the brake calipers were seized Then it struck ME ! , Man was I p_ssed off with myself to say the least![]()
