seahouse wrote:After two years (and who knows how many more) without attention, the system as it is has proven itself without failure. It’s only going to get better when routine maintenance is done.
I think going to the trouble of replacing something because some people are unfamiliar with it is not a good reason to do so. In fact, while it may or may not be the case here, very often the best systems are the ones that are not so common in the mass market. But we are in internet land, and what is a normal best practise in one region, might be unheard of in another.
If there will be sufficient clearance under the rubber dust cap, replacing the buttons with standard grease nipples, as suggeted, is a viable solution, but I suspect that the reason the button fittings are there in the first place is because of their low profile under the caps.
- B.
Or wait until you know you have a problem (because it broke) and replace it then. Checking temps on the hub after every use with a cheap IR thermo will tell you all you need to know. Keep a log, when it starts going up a curve, it's time.
