The boat comes with two switches - one for the navigation lights (bow bicolor and stern white) and a second for the masthead light.
I used the much discussed method of using existing mast wiring by using an LED bulb in the masthead light and an LED anchor light at the top of the mast (and running the two lights with polarity reversed to each other). After drilling with 1/2 inch steel conduit thru the styrofoam for close to 20 feet
I chose not to add another switch to reverse the polarity of the wiring to the mast but instead wired in a DPDT relay. Essentially, the relay switches the polarity of the wires from the masthead switch and uses the voltage from the running lights as the trigger to do this.
So, operation is as follows - Running Lights = switch 1 (SW1), Mast Lights = Switch 2 (SW2):
Sailing: SW1 on, SW2 off [front bicolor and stern lights]
Motoring: SW1 on, SW2 on [front bicolor, masthead, and stern lights]
Anchored: SW1 off, SW2 on [anchor light top of mast]
Works great with no added complexity to the switching.
