I don't know if it come from the factory like that or not, but something isn't right.
The block on the track feeds the sheet into the winch I think too high. So when you take a turn around the winch and pull most of the time the sheet crosses and fouls. Its rather spooky when you have a 25 not wind not being able to free the jenny!
The next thing is the cam cleat is so close to the winch its darn close to impossible to secure the sheet.
I think the block on the track needs to feed the sheet to the winch close to the base of the winch or the winch needs to be raised. Also the cam cleat needs to be moved back away from the winch (aft) so its usable.
Does anyone know anything about this stuff? Is this factory installed? do my ideas make sense?
