I know the specs for the
I'm wondering if anyone has ever actually measured what their M draws with the ballast full, and the daggerboard fully extended?
The reason I ask is because I've had my depth finder read below 5 feet (4.5 feet at one point) with the daggerboard down, and haven't hit anything. (Not that I'm complaining....
I measured how far my daggerboard line drops down into the trunk, and got 54 inches. This is how my dealer set it up, probably giving it a 3 inch margin of error to allow for rope stretch.
In any case, even at 54 inches, my boat should be drawing 5'6", but I suspect it's less than that, based on readings I get on my depth finder coming in and out of the channel. Is there a way to convert how many inches the daggerboard is lowered inside the trunk to the actual depth you're drawing underneath the boat?
Cheers, Joe
