Lifting Rudders Tip
ScottCReeve
Lifting Rudders Tip
Post by ScottCReeve »
I am sure that this is nothing new but I thought I would post it anyway.
Last year I was sailing in the inner bay of Long Point in lake Erie where I have my boat. I went to tack and nothing. The boat would not change course at all. I lifted my rudders and discovered that I had soooo much salad on my rudders it was like steering with beach balls. Sailing in August when the weeds are at their worst, I had to lift my rudders every 20 minutes or so to clear them. I found that they were so hard to lift that I had to put a foot on the top of the motor to get enough leverage to get them to come up. Also like most I always lift them at dock as well. I was thinking of some way to get more leverage to make it easier to lift them and finally put my high school physics to work.
The attached pic's show what I came up with and they work like charm. I can now one arm them up with no problem.
I simply used 4 fairly solid L brackets, cut off some of one side and drilled a hole in the elbow of each of them to pass a bolt through and attach to the rudder as the fulcrum point. I did not want the bolts rubbing on the rudder's surface so I used some pex pipe as a buffer and spacers. Painted the whole thing with white rust paint and attached the lines.
Hope this is of help to others.
Scott
Re: Lifting Rudders Tip
Nice idea and execution...l :D :D
bartmac
Post by bartmac »
Nice...I've found the quick lifting of rudders to be a problem as a 26x steers like a barge without the rudders down ....but the dimensions of your mod would be good...I'm lazy...sorry efficient don't want to reinvent the wheel if I don't have to
ScottCReeve
The L brackets are 8 inch and I cut one side off each one just past the closest hole to the elbow. If I did it again I might have cut it and left the 2nd hole and used it instead of the one at the elbow. The rudders are 1 1/4 inch wide so I used 2 1/2 inch bolts and cut the pex spacers at 1 1/2 inch's. That's about it. Paint it and attach. I did use bolts that are not threaded all the way to the head so when I tightend the nut on to the bolt they would not pinch the 2 brackets too much. I think they are called carriage bolts.
DaveC426913
Post by DaveC426913 »
I'm going to install those on my :macx: ! Thanks!
Bill at BOATS 4 SAIL
Sailboat: MacGregor 26D
I just put the boat in reverse for a little while.
Cool idea.
I can't tell what they would look like with rudders down. Do they get wet?
ScottCReeve
They are just slightly below the water line. That is why I used rust paint.
ScottCReeve
I am hopefully going for a sail today and I will take a picture
ScottCReeve
Here are a couple of pic's from todays sail
You can see how they ride in the water with the rudders down
So they are just below the water line
bartmac
Post by bartmac »
Nice simple solution....might look to use the same principle but in Stainless...most of our sailing is in salty water
Gotta love Great Lakes sailing.... :D
