How do you take off the boot stripe
FinallySailing
Post by FinallySailing »
Hi,
what is an easy way to take off the boot stripe on my 26S ? It is not painted but looks like a thick vinyl tape. It is starting to look badly hacked now.
Doug91mac26s
Re: How do you take off the boot stripe
Post by Doug91mac26s »
I replaced mine. Used a heat gun, carefully to soften the old brittle boot stripe tape. Be careful to not apply too much heat though. Then I wiped it down with acetone prior to applying the new stripe.
Paulieb
Post by Paulieb »
A Hair Dryer on High will also do the trick without worrying about scorching/burning anything. I would also recommend a plastic putty knife. This has worked great for me in the past.
Paulieb
FinallySailing
Thanks guys for the prompt response. I will try the hair dryer first and see how it goes. :)
Grinnell
Post by Grinnell »
What is a "boot stripe"? I have a 26S, but I don't think I have a boot stripe.
FinallySailing
Grinnell wrote:What is a "boot stripe"? I have a 26S, but I don't think I have a boot stripe.
Its the stripe on the hull just above the waterline.
