I would echo Mastreb’s sentiments on the Ford Flex (/ Lincoln MKT). You need look no closer than your back yard; both are manufactured at the Oakville plant.
Test drive the Ecoboost models. I’ve been patiently awaiting a styling change on the MKT, though. Haven’t really bought cars on the basis of styling in the past, (other performance characteristics take precedence), but the performance of the twin-turbo Ecoboost MKT very much lives up to the V6-that-feels-like-a-V8 hype (and I should add that, other than motorcycles, I have never in my life (yet) owned anything but V8’s). I would have one in my garage now if it weren’t for the outlandishly pretentious styling. I test drove several times, but never ordered one, yet. Hence the consideration of the Flex, because I can only put it off so long…
Both are recommended by Consumer Reports, the MKT with better-than-average predicted reliability.
I suggest the Ecoboost because of the torque (355lb-ft, IIRC) and turbo-generated hp is more real-world power than normally aspirated hp (which diminishes with altitude ASL, right when you need it – to climb hills and mountains with the Mac behind). And how many people drive at sea level (where the hp numbers are calculated) – after all- that’s what the Mac is for!
The Ecoboost engine option is $1000’s less this year than previous years (I believe). Gives good fuel mileage when you don’t need the power, and good power when you need it.
It’s direct injected (yes, like the E-tec technology), so no turbo lag. I think it will be the near future of internal combustion engines – (DI combined with turbo boost) just this week I saw the first TV advertisement specifically for it – and it’s been available for several years. With all wheel drive for the slimy ramp.
The trailer towing inertial anti-sway program will also bring sway into check by automatically applying the brakes to individual wheels. It’s another layer of safety – they’ll all have to have this eventually, mandated or simply to be competitive (just like seat belts, airbags, ALB, stability programs etc. etc. etc.), as I look at such things, it could save your life, so why not have it now?
Some of these features simply aren’t available on other comparable vehicles.
I’m not trying to sell you, everyone has their own individual priorities, but you might want to check them out.
- Brian.
Edit : Ok, just read your post above, ahead of me (got sidetracked), I would guess if you don’t like the look of the Flex, then the MKT is NEVER gonna fly!!!!
