Mac26Mpaul wrote:Thanks Cruiser. That link kind of scares me in how much dribble I'm sure I will have to wade through, but yeah, I guess I should try and dig in to it
No Paul, that document is actually very simply you just go down to the bit on yachts, as oppossed to dragon boats, rowing sculls, etc. - the document isn't very long actually - very refreshing.
Couple of bits of definition wording take a bit of digesting but if you look at the vehicle/trailer diagram first you can then go back to the definitions to clarify what they mean. The overhang across the rear of the vehicle took some digesting, for me, but once I went back to the definition I could see what they meant.
Mac26Mpaul wrote:.....Is moving the V of the trailer really the answer? I mean isnt the boat designed to sit in a specific spot on the trailer to get its weight distribution etc right ?? Arnt you messing with this by having the boat further aft on the trailer than it is designed to be ?
I presume you are refering to the rubber "V-block" that the front of the bow goes into? If you moved the block back say 2" (or whatever your normal gap) from where the bow has to come up to you could then winch it up tight on the block whilst in the water. Once you pull the trailer out of the water it will then flex back and leave the 2" (or whatever) gap - you then just shift the block back firmly against the bow.
I think if the bow is held tightly in the "V-Block" block plus tightly on an extra bow roller under the front of the bow it will make the boat a much firmer and steadier fit on the trailer. I am thinking of putting on the underneath bow roller as well as say a 6" steel "V-Notch" lined with carpet - the roller would sit on the back of the support bar and the "V-Notch" on the front. Both would be height adjustable and the bow would end up being supported by the "V-Notch" rather than the roller, once the boat was firmly sitting on the trailer.
