shroud covers?
Locked
Matt 777
shroud covers?
Post by Matt 777 »
What size shroud covers fit the mac? West Marine has them available in 6' lengths / split - snap on types.
Cable Cover, 3/32", 6FT 251
Cable Cover, 1/8"; 6FT 252
Cable Cover, 5/32"; 6FT 253
Cable Cover, 5/16"; 6FT 256
Cable Cover, 1/4"; 6FT 255
Cable Cover, 3/8"; 6FT 257
Cable Cover, 3/16"; 6FT 254
Dan B
Post by Dan B »
I just put the 5/32 size on last weekend. What a fun exercise that was. They fit, but there is a very slight gap once on. I you go larger, don't need more than an extra 16th inch.
Sloop John B
Post by Sloop John B »
I have just replaced the PVC with flexible one inch inner diameter clear plastic tubing. 4' for the shrouds, 3 ' for baby stays.
This stuff comes rolled up and wants to stay 'rolled up'. I hope the sun, with the mast up, straightens them out.
I think the shrouds should be in open air rather than corralled in a sheath. They are easily inspected for any corrosion, kinks, or strand breakage.
SJB, I think what Matt was referring to was thin, plastic sleeves that fit over the actual shroud cables themselves... they prevent chafing of the sails on the metal shrouds.
Now, if I'm correct, what you've referred to are 'boots' to go over the coupler that holds the shroud to the deck-mounted chain-plates... these would be like short, plastic tubes (though some fancy folks make them out of white leather!)
Both are good additions - I have them on my Boston Whaler Harpoon and plan to add them to the Mac.
Matt 777
Post by Matt 777 »
kmclemore: exactly - just trying to figure out what the optimal size would be, from Dan B - sounds like the 5/32" are just a shy small.
Post by Frank C »
I don't have shroud covers, but the shrouds are definitely 5/32" (no clue about the baby stays).
Think I recall someone's theory that one size larger is easier to install. Might try getting two each of the 5/32 and 3/16" then see which provides better service over a season.
Locked
