I went with the
simply because I bought new. I have a friend here in town who has an
and I've been aboard his a number of times when we're both at the public docks at the same time. I'm 6'5, so I can probably speak to the size issue pretty well although I'm 245 lbs so not very bulky.
Firstly, I sleep in the aft berth on the starboard side. There's just barely enough room for me, but I put a pillow over the liner where my head is, which works just fine but I am longer than the berth. I sleep fully stretched out on both the port side seats with the galley slid aft or on the dinette berth, both of which are literally big enough for anyone. The dinette berth can accommodate anyone who can enter the cabin, it's 7'6" long and 4' wide.
The cockpit of the
is cramped with six aboard. I've had up to 11 people on board which is about one more than the absolute limit in my opinion, but that's five adults and six kids so kind of the equivalent of eight. Kids have no problem with the limited cockpit space as they get around like monkeys, but it's a clear annoyance to big groups to have to have everyone shift around every time you tack. For just my family (2 adults 3 kids) the cockpit is exactly the right size. If you're going to have larger groups aboard, you'll appreciate the bigger cockpit of the
, if it's just going to be you and the wife and maybe another couple on occasion, you'll appreciate the smaller cockpit of the
. I don't mind the step over the cockpit into the companion way at all--frankly I don't even notice it. I becomes very automatic very quickly.
I prefer the interior layout of the
however, the cabin does seem to be much lower and it's frankly more difficult for me to get around inside for that reason. The difference may be only an inch or two, but it's a pretty critical few inches at my size. I'm slouched way farther over on the
when moving around inside. I think I would also prefer the flatter stern hull of the
for planing as my
(usually heavily loaded) seems to "plow" more than "plane". I get the same speeds as everyone else under power with my motor so it clearly is planing, it's just very wet.
All in all, we need the larger cabin of the
and all things considered, it's the better boat for us. But if my criteria were even slightly different (such as if I was shorter), I'd likely get the
for the better interior layout and the flatter stern hull.
