I'll be using a Ram Mount to hold the unit on the pedestal. I figure this way it will be easy to remove from the boat when not on board and it will swivel so I can view it from the windward side when heeling over. Currently I have a compass mounted on top of the pedestal:
B and Andy sailing by Brian Hart, on Flickr
I kinda hate to lose it but I think I'll put the Ram Mount on top of the pedestal and ditch the compass for a bulkhead mounted one. Alternately I could mount the Ram off to the side and keep the compass but I think the 740s will stick too far out into the cockpit space if I do that. I'll have to measure for sure once it gets here.
As part of the install I've gone ahead and run new beefier power cable up to the pedestal and I'm installing a 6 fuse block inside the pedestal so I have room to add a few other items - at the moment a 12v power outlet and the charging station for my wireless WHAM VHF mic. Later I might add some cockpit LED lighting and maybe a washdown pump wired to the pedestal. I've used 5200 to secure a wood block inside the pedestal that I will screw the fuse block too. I like fuse blocks - no more mess dealing with inline fuses.
I'm going with an in-hull puck transducer in my "X" and trying to decide where to put it. After searching the site I think I'm going to place it under the galley, more or less as far forward as the cable will reach. It seems like there's a good spot to make contact with the hull under there (and not the water ballast tank). Anybody that's done this already want to chime in with any helpful hints?
I'll also be running a signal cable to tie my Uniden VHF in with the 740s via the NMEA 0183 input/outputs so I can take full advantage of the DSC capabilities in my radio. I would have done that today but I forgot to buy the cable.
I'll post pics too once there's something to post. Right now all that's visible is some cable in the bilge and the inside of the pedestal so nothing exciting yet.
