Pilot: Allow me if you will to play Devils Advocate.. all the while remembering I am not searching the Internet but relying on a lot of training trouble shooting and there by hands on experience.......
#1. What do you hope to accomplish with this In Line Breaker?
Might I remind you that the very worst place Inside your home to have your breaker panel is in the ..... Basement! Humidity and there by corrosion are your breakers biggest enemies..
#2. What size in-line will you be installing? 15 amp? 20 amp? Heaven forbid a 30 amp!! Though its true most every marine hoook up will offer no less than 30 amps..
What quality and size of wire and outlet /receptacles did you install? Typical #14 wire or did you go to 20 amp #12 or 30 amp #10? your outlets ? Are they the cheap 89 cents to $2... 15 amp variety? Did you stab them in for the connection?
Is the first outlet after the breaker or at least ahead of any consumption device a GFCI and is it properly wired?
All that In Line breaker is doing BTW is limiting current flow.. amp draw of the entire system...
#3. Nothing on your boat should be drawing more than a few amps . I suspect the coffee pot will be the biggest draw and its protected of a sort by a short cord of #14 - 15 amp wire..
In Line breakers on boats and campers and Motor homes...a great idea as long as you understand what it is they will actually accomplish.
My SUGGESTION ..Install your 30 amp in line or a 20 amp..Then split it to two separate in line breakers of lesser size , say 10 or 15 amps and have them operate 1 or 2 .. maybe..........3 devices each.. again the first outlet coming off each new in line should be a GFCI..
Your boat for obvious reason is not wired using EMT its Marine Romex at best.. There has NEVER been a house fire with the use of EMT and metal boxes no matter what happens inside that pipe or box....it goes to ground and everything comes to a halt.. NOT SO with romex or smurf tube..
Last but NOT least buy that GFCI / Polarity tester .. its $10..
rjhpilot91 wrote:The question arises since I'll be staying at 3 different marinas in 4 days and would like to use some shore power to use a laptop, charge batteries and such. You never know what their setup looks like till you get there. I definitely want to be on the safe side and do the smart thing such as adding an inline breaker.
