hoaglandr wrote: Is there any reason that a fixed length line won't work? Will the lazy jack interfere with the performance of the sail in any way?
I don't see why a fixed length line won't work. To be honest mine is not completely fixed length. I have about 2' of extra line so that I can adjust if necessary...but have never needed to. I could cut that extra 2' off but sure as the sun will come up in the morning if I cut it off I will need it.
IMHO there is no interference when under sail. If the sail is really full...say a broad reach...then the sail will touch the LJ lines. But if there is any degradation in performance it is less than 1.37%. I leave my LJ system up all the time unless I am putting on my cover. Takes maybe 60 seconds to unclip two carabiners at the end of the boom...clip two carabiners at the front of the boom...pull the lines to the mast...and then another 2 minutes or so to throw on my sail cover and snap and zipper it closed. And I normally only do these steps at the dock right before I pull the boat out.
And to add to the discussion...I also have single line jiffy-reefing very similar to the picture that Judy posted but after the line goes through the forward reefing cringle it comes down to a turning block on the boom and runs back to another turning block on the aft end of the boom then up to and through the aft reefing cringle and then down to a metal piece attached to the boom where I tie it off. So from the cockpit I pull on the reefing line and this will pull the forward and aft cringle down to the boom...aka "reefed". I do have the sail slugs "stacked up" on the slug-stopper just above the stop but this only results in the cringle being maybe 6-8" higher than if it was as low as possible.
No help with that "hook thing"...no idea what that is.
Five very nice mods to have if you plan to go single-handed:
1) Wheel or auto-pilot
2) main halyard led to the cockpit (raise/lower the main without going up to the mast)...and my main does have a "haul down" to pull down the main...you can see it in the video
3) Roller furling foresail (Genoa 150 in my case with CDI FF-2 Furler)
4) Lazy Jacks to catch the sail when you lower it
5) Reefing system led to the cockpit (no need to go up to the mast to reef)
Are there many who do single-handed without these things...certainly and more power to them. But does having these things make life easier and safer...IMHO they certainly do. My boat came with 2-5. I bought the Wheel Pilot which can be expensive. Not sure the cost of roller furling. 2,4, and 5 are pretty cheap I think.
Here is my video demonstrating me single-handed furling the foresail and lowering the main into the Lazy Jacks and I stay seated in the cockpit the whole time:
Lazy Jacks and Roller Furling
Sailing on König
