I'd opt. for a large 10 ' x 10' white plastic tarp throw it over the boom for a boom tent , you can also do this up front with a smaller Tarp
That was the same thing that happened to us ! The Gin Pole base bent when the mast swayed out over the boat next to us. I am hoping the baby stays will prevent this . It seems to me they should , but you are saying they won't . No offense , but I hope you are wrong !Highlander wrote:The baby stays are part of the mast raising system 0n myI used to leave them on all the time . on the
they are made of 5/16" line I beleive & they attach with u-shackles to the two stanction bases on the deck & on the mast bail about 6ft up . I have raised my mast on the water a few times & several times I had problems when someone would go by doing 20mp/h in a 6mp/h zone creating 2-3ft swells or in a gust of wind as the baby stays do not give much support when raising the mast on the first one third going up it can sway quite a bit and bent my gine pole ss base plates . So I made & installed baby stays on my gin pole also , I
Nobody is saying its not safe but it is a major PITA if the conditions are not right , try doing it in three ft swells with dorks in 35ft & bigger boats cruising by you doing 20mp/h or more in 6mp/h no wake zonesLoefflerh wrote:With the factory installed mast raising system its absolutely safe and no problem to raise / lower the mast on the water. Although my boat ( now a M, before that I had a X for 10 years) is stored on a lift, every time I go out I have to go underneath a bridge and I have to lower and raise the mast completely. Alone - I look for a dock to tie to and raise the mast, if somebody is with me we do it underway going slow.
Hans
We practiced in the backyard , several times ,and raised everytime without a hitch , but that was under perfect conditions .Highlander wrote:Nobody is saying its not safe but it is a major PITA if the conditions are not right , try doing it in three ft swells with dorks in 35ft & bigger boats cruising by you doing 20mp/h or more in 6mp/h no wake zoneswaving to you as they go past totalally oblivious to what they are doing
they should not be riding a bycicle never mind driving a boat
it is not always poss. to get into a nice quite cove with no wind & or wake to perform this duty
But that said themast raising system meets the min required status for what it was designed to do I've had issues with it when raising the mast in my driveway on a windy day !!!
