Yer right - don't want to heat the head, that makes the whole head expand (and because it expands more than the bolt, it will actually make the bolt "tighter" - squeezed against the head harder). If you're going to apply heat, you want to heat the bolts only because then they grow longer, which reduces the tension in the bolt, reducing pressure against the head and threads, etc. But truthfully, you SHOULD be able to get the head bolts out without heating - if you were re-building an antique that had been stuck together for 50 years, that may be different, but these you should be able to remove - albeit, you should remove them in factory torque order, and only a small amount each until they are all lose - 1/4 to 1/2 turn each until you've loosened them all. May not be as big a deal on a more square-shaped head as opposed to a long skinny one, but good practice nonetheless. The CO2 did the same thing - froze the head, shrank it compared to the rest, which has the same effect as heating the bolts - makes the bolts longer than they were in relation to the head.
Catigale wrote:Learns tonnes and have funne too!
That's great!
Oh, Cat, didn't you post a mod recently where you showed how you attached a special "not-quite-to-the-waterline" lanyard to yer motor brack...um...
Funny thing divecoz, I was reading some of your posts and thinking the same about how much we think alike - EXCEPT - I don't have a boat yet.
And I don't have time to "play" on motors and stuff anymore...although the mr.fixit/inventor in me never stops thinking about "stuff" I CAN do once I get my boat... Give me a holler when you get to the area - I'm working on hooking up with jschrade and DaveB too cuz I travel the whole west coast of the state - and Sumner's supposed to say hello when he gets down here too - we may have to plan a big west coast meet-up!
