Catigale wrote:Gotta give the Admiral credit on this one. Ive never used my motor to get an anchor out. Although this isnt a danger on our relatively underpowered boats, the guys who died in the Ocean down in Florida sunk their boat trying to drive an anchor out this way on a powerboat. Found them several days later, with only one survivor.
These guys were in a massively powered-up fishing boat, and probably slammed the throttle on twin 900 Hp motors to try to break their anchor out, swamping the stern and then losing the boat.
This would be impossible to do in a Mac - both due to underpowering as well as flotation!!
If memory serves, when the guys in Florida couldn't get their anchor up, they did what any lug-head would do, threw the engines in reverse full throttle trying to brute force the anchor loose. Good anchors doing what good anchors do, it set even deeper and when the rode stretched to its max the only place for the boat to back to was DOWN. The engines essentially pulled the transom underwater capsizing the boat. Similar to the way
this E-Tec promo video capsized the other boat.
Frankly, I've never had a problem dislodging an anchor set in a regular bottom.
I'm sure that anchor buoy thing works well, but storage on my Mac is at a premium and another big object to store is not in an option.
What Steph describes is all you need to do.
The simplest method is to drive your boat up as close to you can to be directly over the anchor and cleat it off. The anchor needs scope to keep the flukes from pulling out. By doing this, you are defeating the anchor's design to hold. Most of the time, the bobbing of the boat will rip it out. If not, go back (or have a helper) SLOWLY drive the boat in the opposite direction you were swinging on. The key is "slowly". Don't jam down the throttle or you will cause a problem.
This technique has worked on every boat I've been on, including some larger heavier anchors.
Ideally a trip line and buoy is best, but honestly I've never had the patience to connect one. If anchoring in rocks or lakes with a lot of submerged logs to be concerned with it might be worth it.
Now if it doesn't come out this way, you may be caught on something. Last year my son couldn't get the anchor up and complained it was too heavy. I thought he was being a wimp. I went up and sure enough we managed to grab a submerged tree. If you hook a cable or rock or some such thing, well you are in a world of hurt. If not prepared to dive for it, you could tie a fender to your anchor line and come back another day with some underwater gear to try and retrieve it.
