Fuse panel w/dual battery monitor
eaglelakejames
Post by eaglelakejames »
Ahoy,
I'm looking for a 3 switch panel with dual battery monitoring to replace the one I just broke a fuse holder in.
It looks just like a regular panel but has a toggle switch to read either of the two batteries.
I've looked in all the usual places on line and am stiking out.
Any sources? :(
 ! kmclemore:
Fixed spelling :)
c130king
Re: Fuse panel w/duel battery monitor
Post by c130king »
Have you looked at Blue Sea Systems?
5 Position DC Bus with Voltage Meters
But looks like their 3 position panel doesn't have the meter.
I have the 8 position panel but with no meter.
Good Luck,
Hovez
Post by Hovez »
You need this:
http://shop.jachting.info/index.php?mai ... cts_id=548
Sorry it is Czech, but you can see the producer - MARINETECH
Doug91mac26s
Post by Doug91mac26s »
Can't you just replace the broken fuse?
eaglelakejames
Re: Fuse panel w/dual battery monitor
I broke the housing that holds the fuse and the housing is attached to the buss bar in the back. If I could find an identical fuse holder, a fix might be possible however if I could replace the unit for under $100 I think I'd be money and time ahead. I'm going to follow up on the Chech lead in a previous post.
eaglelakejames
The Chech link is exactly what I need. A "Marinetech" panel but I can't find a US source or any other info related to "Marinetech" products.
Do you speak/read Chech? If you do please throw me a line!
Getting closer!
Thanks
James
eaglelakejames wrote:The Chech link is exactly what I need. A "Marinetech" panel but I can't find a US source or any other info related to "Marinetech" products.
Getting closer!
Thanks
James
Try this!
http://translate.google.com/translate?u ... =&ie=UTF-8
Hovez
Post by Hovez »
MARINETECH is a German company:
http://www.marinetech.de
You can download a catalog here:
http://www.marinetech.de/index.php?id=kataloge
Catalogs are in English language too. But I don´t know if they have some representative in US.
Does it look like this panel
Does it have the square fuse holder end caps that need to be pryed off with a small screw driver or a pen ! like this
If so let me know I look up the make of mine I beleive W/M sells the fuse holders I know Dowsar marine sells them because I also broke one & replaced it from them also bought a spare
Ps let me know I'll try to take a better pic this wk-end
It seems like it would be so much easier to replace the fuse holder.
Or just replace the panel with a standard one and wire a separate panel for the Batt A-B voltmeter.
Currie
Post by Currie »
I made mine on the cheap with a SeaDog panel, a couple of Teleflex voltmeters and some switches from RadioShack...
chefmike
Sailboat: Venture 2-24
Post by chefmike »
Is this it?
Thats the one I have yes you can buy new fuse holders for about 3-4$
eBay?
fuse holder.
By the way.. I HATE these cheap fuse holders. You need to stick something in them to pop the fuse out. I'm replacing mine with a normal fuse holder.
Bobby T.-26X #4767
Post by Bobby T.-26X #4767 »
chefmike wrote:Is this it?
that's the animal...I have that same set-up on my X.
Bob T.
"DāBob"
Dinghy Motor: '06 2.5-Suzuki
