Sumner wrote:KayakDan wrote:
I can purchase a booster like the Wirie,that plugs into a USB port on my laptop. There's $300 spent
I initially was going to go with a USB radio, the one used in the Wirie, but after all the reading I've done now feel that the Bullet is superior and for that reason if I wanted to buy a complete ready to go system would go with the Island Time or the Bad Boy (the expensive one) as they use the Bullet. I think the comparison chart for the Wirie is not a fair comparison as they try and put doubt in your mind about the Bullet. Note is is at the far end of the chart from their product. Also in this photo you can.............
.....see Bullets, just like the ones in the kits, being used outside in a very industrial situation. They are at the bottom of the antennas by the workers. You would never find a USB radio in one of these situations.
If you don't mind hoisting an antenna 10 feet or so when using it and having the cord going out of the cockpit the USB radio can still get out there pretty good and would be fine for close in WiFi like in a marina or near one that has WiFi.
I'd use the radio that Wirie uses that you can get for under $50....
http://www.data-alliance.net/-strse-73/ ... Detail.bok
or this 2000 mw....
http://www.data-alliance.net/-strse-158 ... Detail.bok
Hook it to this antenna...... ($24.00).....
http://www.amazon.com/exec/obidos/tg/de ... N&v=glance
with this connector.......($6.00)...
http://www.data-alliance.net/-strse-144 ... Detail.bok
and then a USB cable up to 15 feet or so...................and if you want to mount it in an enclosure for some weather protection (other wise just put it up when the sun is out) add something like this....
http://www.data-alliance.net/-strse-161 ... Detail.bok
I came close to this as a solution and it isn't a bad one, just not as good as the Bullet if you are really trying for long distance. The Bullet is harder to setup if you don't buy one of the above complete kits, but you can mount it any distance from the computer you want (not limited by the 15 foot USB cable -- you might be able to use an 'active' USB cable for longer distances, but your USB port might not have the power for that). The USB option is more user friendly though and if you are not trying to connect from a mile or more out might be the easiest and cheapest way to go. What I outlined above is basically what you get in the Wirie kit and you can see it adds up to a lot less.
Good luck,
Sum
Hi Sumner,
Just as a matter of full disclosure, my name is Mark Kilty and The Wirie is the product I developed and our company sells. I do not post on message boards, except when inaccurate information specifically about our products is posted or about information we have on our web site is questioned.
I want to point out a few inaccuracies about your post, just to help educate everyone a bit about Marine WiFi in general. I am not trying to "promote" my product, however, I feel it is necessary to state the facts.
The cost of The Wirie is $250, not $300 as stated above.
Our product comparison chart was written to let people know the Bullet is not a good solution for the marine environment. You can say its "not a fair comparison", however the Bullet2HP is not waterproof. There is no debate on this. Put one in a bucket of water if you don't believe me. They are OK if water only hits the unit from above, vertically downward, as in rain (even then, many have leaked). Anything from another direction and the unit will have issues (like when sailing for instance).
The photo you posted: I would not use USB their either, there is no computer to power it. They employed network engineers and have the ability to run ethernet cabling and power it from long distance with high voltage. PERFECT application for the Bullet, and exactly what it was designed for! To say therefore its perfect for a boat, is a pretty big leap.
As far as attempting to list our parts to build a Wirie, we encourage you to try if you would like to attempt to save some money and are technically inclined (just as you can purchase a Bullet and put together the parts yourself instead of buying a "kit"). However, there are custom pieces to our product, but feel free to use what you listed and see how long it holds up on your boat. We have looked at many different parts to use in our manufacturing process, and believe me, we didn't come up with the parts for The Wirie overnight.
Just so you know, the 2000mW Alfa adapter does not work as well for b/g networks as the adapter we are using, you can find our test results through our FAQ, right above the links to all the unbiased issues with the Bullet and water.
Your statement that USB devices wont give as much range as Ethernet is 100% false. No one could ever make a legitimate claim like that. USB and Ethernet are cables, they have nothing to do with how well a consumer based WiFi device works. We connect from over a mile on a regular basis, and have connected much further as well. The Bullet and The Wirie will preform very similarly, even though one is USB based and one is Ethernet based.
There is no issue running USB Active Ext Cables up to 80', assuming your computer was built to the USB 2.0 spec, which any computer built in the last 5 years is. (Also FYI, the POE cabling to power the bullet will lose too much voltage over the run from a 12V battery to go much over about the same 80')
If you have any questions about The Wirie I can answer for you, or marine WiFi in general, please don't hesitate to contact me at
mark@thewirie.com or
http://www.thewirie.com, but I won't post any follow-up information on this site as I feel it would be inappropriate and not in the spirit of forums.
Have a great day!
Mark
