Thanks that gives me an idea. I was thinking rubber mounts right under the Honda, but if that doesn't work or in addition to that maybe rubber mounts for the struts that mount the platform for the Honda and alternator.kmclemore wrote:I also have a Honda 1000 generator on board, to supplement the panel. The Honda puts out about 8 amps at 12v (96watts). It is indeed quiet, but as noted does produce vibration if placed on deck. I solved the vibration problem by suspending it on bungees... they go down from the bow pulpit, through the generator's carrying handle, and back up the the pulpit... works a treat. The generator stores nicely under the cockpit's aft seat.
Your solution to supplementing the panel with the 8 amp output of the Honda is a good example of how different our needs can be. I use a CPAP machine at night and it uses 6 amps for 6 to 7 hours that I use it. That is about 39-40 amp hours. It would take running the Honda 1000 about 5 hours to replenish that in my case, but obviously for your needs you are just fine. If I was using the Honda 1000 I would run a 12 volt charger off of the 110 volt side, but there again you don't have to.
My thought was we really don't need 110 for anything on the boat as everything runs off 12 volts. Well the exception to that has been the laptops, but that is going to change with a 'true' 12 volt computer.......................
http://purplesagetradingpost.com/sumner ... Index.html
I'm looking forward to putting it together, but will have to wait a couple months as we need to buy a new outboard right now.
c ya and thanks for the mounting ideas,
Sum
Our Mac Pages
Mac Links
