I replaced mine with a stainless steel bolt that i cut the thread off and drilled to take a stainless steel "R" pin from whitworths
I use this method for all pins except where the baby stays attach to the mast
Allan
front mast stay pin
- trip01
Re: front mast stay pin
Allan,
I found these...
This one would support a captive cable.
http://www.whitworths.com.au/main_itemd ... lutePage=1
or..
http://www.whitworths.com.au/main_itemd ... lutePage=2
Kind Rgds
08 26M
I found these...
or..
Kind Rgds
08 26M
- Nautek
Hi Dave
I used the retaining clip just because I had some however the humpback retaining clip looks good too
The chances of the retaining clip coming out is remote whereas the humpback might under some applications
Horses for courses
Just carry some spares
Allan
Horses for courses
Allan
Nope the M mast is bigger & stronger & longer. the X mast at 28ft is stretching the limits of that mast. the
has the same mast as the
only the
mast is 24ft two sectional I extended the mast on my
to 28ft & made it a three sectional mast with a second set of upper spreaders & upper jumper struts it has two forestays & four sets of shrouds supporting it ten times more support than the regular
mast at the same height
Now go listen to me ya'd think I was from TX or something
