Rainer
Which Force Required for Winch at Mast Raising Pole?
- 2BonC
I´m going to change the mast raising system of my
to one with a cable winch attached to the raising pole as it is for
. Now I´m not sure about the power the winch must be able to handle. I ordered one which can pull 350kg (about 940 pounds). But with 4 kg (11 pounds) this seemed to be way to heavy to me. What are the winch-size and approximated weight of Your "home made" mast raising mechanism? Does anybody know the size of the winch of the custom made raising pole?
Rainer
Rainer
- pokerrick1
- Sailboat: Venture 23
Re: Which Force Required for Winch at Mast Raising Pole?
Call the factory and ask Mike Inmon. He has experimented with MANY!
Rick
Less
Rick
- Nautek
Hi Ranier
I upgraded mine also and found that finding a wwinch small enough was a problem
I also came up with a 350kg winch which is way too big.
I think the M size that I have seen was around the 150kg
It is not a heavy mast and does not take much effort
Allan
Allan
Capt Capsize
I used a 1000lb winch or about 450Kg winch when I converted my X original mast raising system to the M type. I choose it because it mainly because had the most reliable direction switching cog mechanism. Some of the winches I looked at had very poor functioning of the reversing mechanism. The tension in the raising system is a function of the geometry created by the mast attach point. I use the jib halyard as my attach point. The farther up the mast you attach the more leverage and lower the tension.
- Hamin' X
The mast raising kit that I have on my
, has a very small winch (not sure of the capacity). It is a brake winch. No cog mechanisim, just turn one way, or the other. Works very well and easy to crank. I have been using it solo, with a totally useless right shoulder, no problem. It is the mast rasing pole for the
- Nautek
Rich
That's the size winch I was looking for but couldn't buy one that small in OZ
Allan
Allan
Dutton - Lainson company . 451 WEST 2ND ST . HASTINGS, NE 68902-0729 PH# 402-462-4141
brake winch mod # DLB800A. RATIO 4.4:1 MIN OPERATING LOAD REQUIREMENT IS 50 LB CAPACITY 330 LB / 150KG
I have the manual that came with my 2008 26M
I will have to go out into my shop and check visualy that this is the right Mod # but as I just got home from work 11.30pm . I will try & do this tomorrow morn OK Guys
Hope this helps
ps WWW.dutton-lainson.com
Hope this helps
- Hamin' X
The entire kit is available from Blue Water Yachts for US $135 +shipping. Part number 3418-1M0. Includes baby stays, pole mast bail, etc. They might sell just the winch, but it is not listed in their catalog.
- kadet
How about this one?That's the size winch I was looking for but couldn't buy one that small in OZ
Looks similar to highlanders specs
http://www.mooreequipment.com.au/produc ... N=48167257
- 2BonC
You are absolutely right, that is making sense however is this the whole truth? How about the length of the pole and the position of the roll at thatCapt Capsize wrote: The tension in the raising system is a function of the geometry created by the mast attach point. I use the jib halyard as my attach point. The farther up the mast you attach the more leverage and lower the tension.
IMO when the mast is in the up position the wire/rope between mast and raising pole should be about horizontally (if not on a sloped ramp
Thank You all for the helpfull responses. Up to now the smallest at a reasonable price I made out was a trailer winch with a pull of 270kg. A new question now came up, what is to be preferred between mast and winch, wire or rope?
Rainer
- c130king
On the
system it is a rope/line...about 1/2" I think. The baby stays are 3/16" wire cable.
- Hamin' X
When using the M system on my X, there is a fixed length of line from the pole to a forward cleat. This fixes the pole at a 45 degree angle forward. The line from the winch attaches to the mast where the bay stays are fixed. turning the winch handle brings the mast toward the mast raising pole and the pole never moves. A little extra tension on the winch allows the forestay with roller furler attached, to be pinned to the forward chain plate/tang with no problem. Very easy to use solo, even when I only have one good arm.
I'd say that the bwy price $ for the kit is most likely the cheapest way to go considering you get all equipment needed just depends "their's that word again" how much it will cost to ship Germany
- 2BonC
I´m thinking about the BWY parts however at present time at BWY I´m stuck at this page:
http://bwyachts.com/web%20catalog%20312 ... ng_kit.htm
A´m I stupid
could somebody else please try and teach me how to order online?
A´m I stupid
- Hamin' X
You could go to their Parts Catalog and follow the instructions. I have done this in the past and it is an exercise in patience. In the end, you have to deal with them on the phone, or by email for payment. I think it will be easier for you to just email your request to accessories@bwyachts.com and be done with it. Describe what it is that you want and that you want to mount it on a 26X. Good luck.2BonC wrote:I´m thinking about the BWY parts however at present time at BWY I´m stuck at this page:
A´m I stupidcould somebody else please try and teach me how to order online?
