opie wrote:...........So after 1 1/2 days with the Edgestar I would need to run my 10amp Honda50 for about 18 hours to make up the 75ah (18 hrs b/c you need more AH "in" than you used "out" , assuming 100 AH needed to recharge, and assuming 5.5 amps available for batteries because: 10 amps available less 2.5 amps (Edgestar at 50% duty) and less 2 amps for the boat. Therefore, 100/5.5=18.............
It is really hard to make some of these comparisons. The Engle uses less amps "when running" than say a Waeco does, so it is easy to say it uses less electricity, but from some reports.......
http://home.iprimus.com.au/rfh/portablefridges.html
http://home.iprimus.com.au/rfh/portablefridges2.html
.....the Waeco is actually more efficient and cycles less, so uses less overall electricity which is the most important aspect, not the instantaneous amperage. After the post about the edgestar I called them and researched them yesterday and I can't come up with a conclusion about their overall usage. They seem to use yet another compressor than the Waeco and the Engle is different also. They do seem to look to have maybe thicker insulation, which might mean they cycle on less, but who knows for sure.
It sure would be great to see a side by side comparison of the different ones over a 3-4 day period using models that are close to the same capacity storage wise.
We are going to most likely get the Waeco 50 and did just buy a second solar panel, an 80 watt that should provide most of the power for it.
As you noted the outboard and a 110 generator or poor choices to provide backup power. We have that covered....
....with the alternator generator I made......
http://purplesagetradingpost.com/sumner ... de-13.html
Actually I think the power needs of any of these are going to be close enough that maybe the deciding factor is how large of one you need and where will it go.
c ya,
Sum
Our Trips to ...
Our Mac Pages
Mac Links
