I don't know, but I did fit an SS141 (10 ft length) to my 2002
without any problems. Yes, I did have to drill a slightly larger hole in the console. They supply a paper template which helps position it but the problem is getting the hole saw centred (note English spelling... I'm a Brit too!) when a large hole already exists there, i.e. no small pilot hole to keep the hole saw positioned and centred. I overcame this by temporarily screwing a larger 1/2" board to the console, aligning the template on the board, then drilling into the board. Once the hole saw has drilled through the board and is cutting into the console, you can remove the board and continue cutting into the console. Easy after that. The upper end of the rack is a snug fit inside the console but it did fit. I'd just check the fit before you start drilling to make sure your console doesn't have any thick spots that might make you want to drill slightly off the old centre just to make sure it fits OK...... I didn't have to do this in the end, but like I said, it's close. I also couldn't find an identical rubber boot for the through-hull hole near the transom (had to cut the old one off). But I found something similar for a power boat and cut it to fit and sealed it with silicone, worked fine.
I hadn't realised just how bad my old cable had been until the new one was in. It was suddenly as light as a feather! It would probably have seized completely this season had I not replaced it. Night and day difference.
