Amazon has it
here for $499. If you haven't, you might read their comments.
It looks exactly like the one I have but mine is some unbranded model. I'm going to assume Honeywell just slapped their name on this same unit that is sold elsewhere under different names.
Yes, it's made in China and as such made like you would expect. I ripped a screw out trying to remove the cover to add the engine oil to the crankcase. Yes it is a 4 stroke. Mine is hard to start if it's been laying around for a while and it is VERY noisy compared to the Honda. It works as advertised and I keep it around for emergency use and if I need power at our dock (we have no shore power at our marina). There is a guy down the dock that has a Honda that he runs to charge his trolling batteries. It's very peaceful and is a quiet hum. This Chinese unit you will hear when running like a softer version of a lawnmower.
I'm not sure how you will soften the noise. There is a mod posted here where they guy put the exhaust underwater. Good idea, but he said the bubbling sound is noisy. I suppose one of those fish tank aerators might turn bubbling into a fizz sound. I experimented with some ideas and most of the sound comes from the block I think. There is some sound insulation, but cheap is cheap.
It works for what I use it for (very rarely) and the cost savings is worth it. However, if I were to use this regularly, I'd seriously go with the Honda. It's powerful and I've hooked a leaf blower to it and even an space heater.
So before you pull the trigger ask yourself:
Will I use this regularly? If so, skip it.
Can I get service? If you can find a Honeywell dealer, then it might be good.
How's my back? This is a heavy unit.
