This is probably good wisdom for conventional speedboats, but I have a feeling that our macs are designed to be stern heavy. Something about a planing sailboat I'm sure. Ever notice when planing, how the bow is lifted up quite a bit more than a normal speedboat?Moe wrote:The way you find this is to run WOT, trimming up from full down, a little at a time, pausing to let the boat stabilize. As you trim up, RPM and speed will rise as the drag decreases, until it doesn't rise any more, and may eventually start to fall. Note the motor's attitude at the point that RPM and speed just stop rising.
If it isn't vertical, and the propellor shaft parallel with the water, you're sacrificing forward thrust to compensate for an unbalanced boat.
I've tried trimming the motor up in many configurations...including with 3 or 4 kids standing in the V-berth, my wife on the front port seat and only me in the cockpit. This should put a pretty fair amount of weight in the bow. I also have a 26 gal water tank under the foreward dinette seat to bring weight forward. It always goes fastest with the motor in the all the way down position. Anybody get different results than this? I've since given up on trim adjustments and always run with it fully down....except for the occasional time that I was running in shallow water with the engine trimmed up, and then forgot to put it back down later.
