I copied this photo, the only one I could find relevant, (thank you original posting member) of a MacX head with the sink removed completely, obviously to increase legroom/usable space in the head.
Are there any other owners that have removed the sink, or part of it, and have good photos of the mod.
My idea is to leave the head's sink itself, and the surround, intact - but remove the "cabinet" below, including the door and the wall, to increase footroom in there, so I can stand up from the seat and pull up trousers.( which is nearly impossible for a 6' human to do with one hand. The other hand has to hold the handle I installed next to the sink.
I need to keep the privacy feature of the door, for guests of the female persuasion, and want to keep the sink as well.
I haven't yet begun to cut the fiberglass liner --- still looking for inspiration on how to "heal" the chopped out liner section, and restore a flat floor and liner wall under the sink. I would leave the sink hollow to the hull beneath the surround, for the drain, hose and thru-hull access, but turn the liner floor up at a right angle onto the starboard wall of the head's liner, up as far as can still leave access to the thru-hull.
'Sure would like some ideas on how to support and build back the liner fiberglass, without attaching directly to the hull, maybe using the kind of material shown in the photo above. Using a pre-fabbed slab of gel-coated fiberglass would make things somewhat easier, if it could be accurately shaped outside of the boat and then sistered onto the remaining parts of the existing wall in there.
