OK, some final tweaks today which I am hoping will turn out to be the ultimate
rig.
1. Took some load off the shrouds. Uppers now 320 lbs, lowers 200 lbs. and added a very modest amount of mast rake.
2. Installed mast rotation limiters. Actually took 5 minutes since I already had the block & tackles from my running backstays (bit of irony) And all mounts were already in place. One end shackles to an eye on the side of the mast. The other end to a large track eye which I have at the front hole of the jib tracks. These eyes are for preventers, but still plenty of room. Of course, the same setup on the other side of the mast. I'll keep the adjustment set at approximately 1/3 rotation. This angle will lign up the mast and boom on a close reach and have the mast a bit to leeward close hauled. With 4:1 tackle on either side, I can later adjust this but will likely keep the setting right there.
3. Replaced shackle on the backstay with one of those chain link shackles (like for trailer chains) though it will stay open. Will never release on its own when lightly loaded and makes for quick release and re-attachment on the other side.
I decided to use the backstay as a runner of sorts. When rotating the mast with the new rig settings and no backstay load, the mast remains straight until it is about 1/2 rotated. This is why I chose the 1/3 setting because it is still straight in this position. It is also aligned with the backstay in this position (the swivel top is straight on the masthead.) The backstay will be shackled to the leeward side, thus causing the mast to bend directly aft, eliminating any sideways force, which would cause the masthead to hook to windward. The huge benefit here vs. conventional runners is if you forget to release the backstay before tacking, it's ok. The mainsail will still pass underneath. It takes just a few seconds to swap sides and you're using the same backstay, so you don't have to slack one off and let it dangle to leeward.
Rotated the mast to the 1/3 setting, put load on the backstay of 300 lbs (per loose gauge) Nice bend in the top of the mast. Forestay went from slack to tight. Mast remains straight (no sideways bend/curve.) Good stuff
Of course, sea trials will reveal the real Macoy. Will post updates when the rain stops and I can get out there.
LD
TRIPPLE REEFED!
