Trailer Wheel Rust
Re: Trailer Wheel Rust
Post by Kelly Hanson East »
In a word, no, they wont prevent rims from rusting
[quote]Lubricated lug nuts will not back off if "properly torqued."[quote]
Thats been my experience over 30 years too. I do like to preach the virtues of hourly inspections of wheels, bearings and tow load when trailering - this has saved my hide a few times with bearings.
puggsy
Post by puggsy »
A longer lasting solution....Even if the wheels do have some rust, get the tyres off them and have them hot dip galvanised. Here is a shot of my VIVACITY trailer that was hot dipped right from new....and its now getting near six years old...and no sign of rust. The frame was done the same and the springs were purchased already galvanised...
As to wheel studs seizing...Give the threads a coat of industrial anti seize...it will not wash out like grease. I had some over from my mining days in the mineral sands industry. We applied it to nuts and bolts that were under running water...and the :macm: trailer gets less exposure than that.
Not the best angle, but the condition is evident....
hope this helps... Puggsy
socalmacer
Post by socalmacer »
I replaced the factory rims with galvanized rims when the original tires wore out (more like rotted) after a couple of years. I figured I would spend the extra time I saved chasing rust on the water or doing other projects. The wheels and tire combinations weren't all that expensive and you may want to consider this option. Just a thought :wink: :macx:
DaveB
Post by DaveB »
I agree, if any trailer is exposed to salt water every part should be Galvinized or Aluminum. My trailer has aluminum Frame and everthing else is Galvinized except springs and Zinc coated U bolts.
DaveB
Post by DaveB »
Forgot to mention..click on picture twice for blow up view.
DaveB wrote:I agree, if any trailer is exposed to salt water every part should be Galvinized or Aluminum. My trailer has aluminum Frame and everthing else is Galvinized except springs and Zinc coated U bolts.
Don T
Post by Don T »
kmclemore wrote:
Don T wrote:No fancy pin stripe though.......I really miss that! 8)
Easy fix - get yourself a Beugler. I have one - an older one with a glass resevoir - and I love it. Not a tool you use every day, but when you need it there's no substitute.
I have one of those too that I use for an entirely different purpose. Funny I never thought of striping them with it. :?
BK
Post by BK »
I use lARGE black plastic trash bags on my wheels when storing for the winter. They blow off easy so i put a block of wood at each end of the tire to secure them. I also put trash bags on my engine, on the front hitch area, on my spare tire and one over the cockpit steering wheel. They all need to be secured with bungies as they will blow away.
OK, I'll bite... what 'other purpose' do you use it for??
Don T
Post by Don T »
Hello,
For a while I did an "outside job" for an electronics firm. I charged them a nickel a piece to paint the indicator lines on fader and rotary knobs. Saved them .40 per knob and made $100.00/hr doing it by hand with the pin striper wheel. Gravy work, made my monthly overhead in 3 days. Spent the rest of the time recording myself and other pet projects. Real nice time of my life.
