I have found that when the wind and seas get hairy, talking 20 kts or more, any headsail just kills the helm and tracking ability. This does not apply to a close beat, but all points of sail from 65 degrees to the wind and lower. The boat just wants to go to windward, even when on a broad reach, even with just a small amount of headsail up, though not as bad. From what I have found, the less headsail, the better. I want to be clear that this is not from wind alone, but a combination of wind and waves. My theory, and this is only a theory, is that the boat is tripping over its own bow, probably because the bulk of the ballast is in the front 1/3 of the boat and the daggerboard is in the same position without any longitudinal rake aft but rather straight down. What I think is probably happening is the headsail exacerbates this issue, due to the shape/weight distribution of the hull & foil. By dumping the jib or genoa, the forward force is alleviated and the bow perhaps rides higher. I have experimented with various sail configurations in the conditions described. Beam reaching with some headsail up is controllable though constant helm corrections are needed. Broad reaches in quartering seas essentially made it impossible to control he boat under main and jib. So, I decided to roll up the jib completely and use anything from a full main to 1st or 2nd reef, depending on wind velocity. I was pleasantly surprised that the weather helm almost completely disappeared and the boat tracked much better. I managed 6 knots consistently in 18-22 kts breeze 80 degrees off the apparent wind on a double reefed main. Heeling was 15-20 deg. I could have gone up to the first reef but it's been a long full day of sailing and I was quite tired, so I just kept sailing this way all the way down to the marina entrance. On other occasions, I have sailed on broad reaches on just a single reefed main with 25-30 kts wind and 3 foot waves (closely spaced) pounding on the stern quarter managing reasonable control, hitting speeds between 8-10 kts. This would not have been possible with both sails, based on experience in the same conditions with both sails….. boat constantly spins out 90 degrees to windward as if the rudders weren’t even there.
Leon
