Most of the time I have to do the work without any help with the boat allready in the water. I use a mast raising system, leave the rollerfurler with genoa allways attached to the mast, have the mainsail stowed in a lazy bag attached to the boom and Ialso leave the shrouds and backstay attached just rolling them up.
I tried to memorise what is required to get the boat ready, in the following You will find a list of the steps I could remember. They are:
at the ramp/crane:
1. dismantling the pair of transport straps and the hook of the winch
2. launch/crane the boat, get it off the ramp/crane-position to a place were it´s possible to stay for the work, remove car and trailer from ramp/crane
in the water:
3. unstrap the backstay (I use cable straps to keep the coiled backstay and the shrouts in position for transport))
4. open the mast carry bolt at the bow and at the mast support in the cockpit
5. move the mast backwards to bring the mast step in position, insert the bolt
6. unstrap the furler with genoa and the furler transport support (I use the mast raising pole)from the mast
7. open the shrouds and bring them in position
8. get the mast raising pole and the attached raising lines in position, connect the furler
9. raise the mast and connect the roller furler to the bow with the eyebolt (that can be a hard thing if You have allready the shrouds in place
10. remove the mast raising system (I don´t have to adjust the shrouds because I leave them allways connected at mast and hull)
11. get the mainsail/boom/lazy pack assembly out of the cabin and attach it to the mast
12. install the boompusher
13. get the lines of the lazy pack in position
14. connect the jibsheet
15. take care of the furling line
16. feed the sliders of the mainsail into the mast, secure
17. connect the main raising line
18. connect the mainsheet to the main sail
19. remove the covers from mainsail and genoa
20. remove the mast support pole
21. stow the covers and tools
22. have a beer
I´m sure I still missed something, anyhow-my question is who does this all within one hour? If so, what do I wrong? How about Your experiance?
Rainer
