I've taken our recently purchased 2001 for 3 trips on our Lake here, and keep getting problems with low idle (around 200 t0 300) and the engine stalls out when it is cold but appears ok or seems that way when warmer but will stall if I shift from forward into neutral to go to reverse which can be somewhat scary when attempting to dock.
Is there some way I can raise the idle speed on the BF50? I've also checked the gas which is new gas and clean but also added the recommended Sea Foam for added protection, and still same problem. I was told that I may have carburetor problems.
Is there a recommended solvent that will clean carburators when added to the tank or is Sea Foam additive sufficient for this?
The engine was sitting for over a year but I don't believe that this is the problem. I have no inline filter, and thinking of getting a water separator if that might help? Thanks in advance for your help, and advise on this
