I was pulling into my slip at the end of a lovely day of sailing last Saturday. I wish I could say the wind was blowing 25 kts+ as it often does, but it was more like 12 kts. The current was strong, however, as it typically is. The tricky part about getting into my slip is to catch the bow before the current takes it away. I use a big loop for a stern docking line which I temporarily throw over the cleat on the dock, then run forward to grab the bow. This time, I wasn't quick enough and the bow got away from me. The boat quickly swung away from the dock with the stern angling towards the dock. I had to move fast so the outboard or rudders don't get damaged. I jumped back on board and decided to use the engine do spring around the dock, since the stern line was attached. I have it a fair amount of throttle. The bow came around a bit but then stopped with the rear corner of the hull pressed up against the corner of the dock. I gave it some more juice. I heard the rusty old cleat on the dock creaking, looking like I am just about to rip it out of the dock. I threw her in neutral quickly *BAD MOVE!* The forces reversed and the boat jolted sharply backwards with much force. CRUNCH! That was my outboard hitting the corner of the dock!
We're talking over $1K to replace the exterior casing. Don't let this happen to you.
Fair Winds,
Leon
