Also, M owners. Check your gas tank strap mounting brackets (4 per tank)
They are Cheap steel and will rust and disscolor the cockpit floor. I replaced them with SS and new straps with plastic buckles.
hehe ... you still believe there is a channel in the mast....RichandLori wrote:Steve,
About two weeks ago, I took delivery of a new 2004 26M from an individual that used it twice. And I went out and looked and I don't have ANY fuel tank strap hold downs my tanks are just sitting there under the seats waiting to slide around, so maybe they were installed aftermarket by the dealer.
On the topic of running wire up the mast (for antenna or such), I was jsut reading the specs and it says that the mast is foam filled, but that there is a tube incerted just for that purpose, so you might want to check it out. That would sure save you a ton of headache!
Regards
FWIW, there's valid debate about the benefits vs. demerits of antenna atop the mast. I suppose if you are frequently 40 miles offshore, you may want that height. However, that cable and antenna represent fairly significant weight aloft, not good for heeling. An antenna on the aft quarter is probably adequate for inshore communications, and the wiring runs are much easier. Just another opinion, YMMV.RichandLori wrote:Well damit that erks me that there isn't a tube in the 26M mast for running wires! How the heck am I going to get my VHF radio antenna up there? .... Yikes, so much for that plan.
What my dealer's guy did (at my house) was take a piece of PVC and sharpen the end of it , like a screw, and ram it down, turn to take some foam out,remove pvc, clean tip, repeat..lots of times.RichandLori wrote:Well damit that erks me that there isn't a tube in the 26M mast for running wires! How the heck am I going to get my VHF radio antenna up there?![]()
Rich
With the boat fully loaded, I was able to get 11+ mph (in choppy water)with the honda (Only had it out a few times) I expect a bit more in calmer water. When we were on our dealer's boat (with far less gear and flat seas) we got 17+. Strip it down and you should get more esp without a ballast.RichandLori wrote:Paul,
I just looked through your website and noticed that you have the same Honda 50Hp that I have on my 2004 26M. I have yet to get it out on the water (only had it for two weeks) and am dying to know what type of crusing and top speeds you are able to hit.
One more question. I noticed that you had and then replaced the tan cockpit cushions that you can get from MacGregor as an option with some blue ones. I was looking at ordering the optional cockpit cushins from Mac. Did you not like them for some reason? Or did you jsut want the Blue ones instead?
Regards
Rich
Good point. I use our hand held 99.999% of the time. I only have the mast top for when the handheld batteries crap out or for an SOS with the SOS button (DSC).Frank C wrote:FWIW, there's valid debate about the benefits vs. demerits of antenna atop the mast. I suppose if you are frequently 40 miles offshore, you may want that height. However, that cable and antenna represent fairly significant weight aloft, not good for heeling. An antenna on the aft quarter is probably adequate for inshore communications, and the wiring runs are much easier. Just another opinion, YMMV.RichandLori wrote:Well damit that erks me that there isn't a tube in the 26M mast for running wires! How the heck am I going to get my VHF radio antenna up there? .... Yikes, so much for that plan.
The mast cap came with the boat (earlier Ms did not have one). If the boat turtles...I think we would have other serious worries than the gas tanks coming looseSteve M wrote:Paul,
Like the mast mods u did. Where did u get the mast-top cap?
And how did u gauge out the foam in the mast?
The SS brackets look good. However in a capsize I think that the tanks will go floating by...![]()
Thanks for the pix.
Steve
I left the cap off the mast...and birds were taking the foam OUT of the mast. I assume for nests. I thought they were building a nest IN the mast..but they didn't . I did think about leaving the cap off and maybe they would create a channel in the foam for meMoe wrote:Not trying to hijack Steve's thread here, but after digging out two feet of birds nests (toilet snake worked great) from our new to us X's mast, I have to ask... do MacGregors not come with a mast cap?
Moe
