Rick
Guide Posts Hold Water
- pokerrick1
- Sailboat: Venture 23
I just noticed when I put my 2006M on the trailer last week that the white caps over the rear guide posts were missing and the posts filled with water. I said to myself "Self, I'm sure the water will drain to the ground some way" - - - NO IT DOESN'T - - - it stays in the tube - - - it won't any more because I will drill some holes in the bottom of the tube for drainage to prevent rust - - - easier than always replacing the caps. Roger; drill some holes in the bottom of the tubes at the factory, please
On second thought, I don't know if the new aliminum trailers have the same setup
Rick
Rick
- Scott
- Sailboat: Venture 25
I drilled holes in mine years ago and they havent rusted out on a 97 trailer. I would still replace the caps though. The worst gouge on my boat is from the raw end of a guide post.easier than always replacing the caps.
I use tennis balls. Cut an X in them and twist them onto the post end.
White tennis balls go on faster.
- pokerrick1
- pokerrick1
- MARK PASSMORE
- Location: Lake Lanier GA - 07 MAC 26M YAMAHA T60 "faster blue hull"
- pokerrick1
Paul S
Re: NUTH'IN
I was being sarcasticpokerrick1 wrote:Basically - - - - NUTH'INPaul S wrote:How much would this have cost to do?![]()
Rick![]()
- kmclemore
Re: NUTH'IN
Yeah, but they're down there with a welder anyway - just use it to pop a hole in the bottom of the tube after they weld it on... easy, and no drilling!Paul S wrote:I was being sarcasticpokerrick1 wrote:Basically - - - - NUTH'INPaul S wrote:How much would this have cost to do?![]()
Rick![]()
of course they would say they can only do so many trailers between replacing the drill bit
Paul S
Re: NUTH'IN
true... is this still a problem with the new aluminum trailers? or is it exclusivly us with the steel ones?kmclemore wrote:Yeah, but they're down there with a welder anyway - just use it to pop a hole in the bottom of the tube after they weld it on... easy, and no drilling!Paul S wrote:I was being sarcasticpokerrick1 wrote:Basically - - - - NUTH'IN![]()
Rick![]()
- pokerrick1
Re: NUTH'IN
What costs more - - a drill bit or a few seconds of aceteleyne"kmclemore"
Do guide posts on new trailers have a hole at the bottom for drainage - - - anybody know?? Cat? If not, then C'mon Roger - - - easy fix at the factory
Rick
- Scott
No problem at all its easier to blow a hole in aluminum twith a welder than steel.true... is this still a problem with the new aluminum trailers? or is it exclusivly us with the steel ones?kmclemore wrote:Yeah, but they're down there with a welder anyway - just use it to pop a hole in the bottom of the tube after they weld it on... easy, and no drilling!Paul S wrote: Rick Smile MacGregor 26M
I was being sarcastic Wink of course they would say they can only do so many trailers between replacing the drill bit Smile
Just kidding, I knew what you meant and just always wanted to do a multi-quote post.
