My first problem was trying to trim the jib from back at the helm with stock cam cleats. The second big thing was my hank on Jib downhaul decided to not work as designed when I wanted to drop it and the Jib jammed half way down, so I needed a way to keep the boat pointed into the wind so I could go up on deck to remedy it.
To fix issue number one I was thinking of getting the Garhauer Swivel Cam Cleats sold by KH that mount on the sail tracks. I was wondering if anyones has used these for a stock Jib? I like the fact they have eyes that will allow you to put a stopper knot into them so you can't loose the sheets, and the possibility of mounting them on the rear tracks on the sides of the cockpit looks promising?
As far as #2, how do you safely point into the wind by yourself and keep it there with canvas up so you can leave the helm? Any way other than to Heave to? I don't have an autopilot
