Anyone ever capsized an M or an X?
empet
Post by empet »
..trying to find the sweet spot in heavy winds. Has anyone ever capsized a M or a X. How was the recovery?
LOUIS B HOLUB
Post by LOUIS B HOLUB »
I notice that the DVD & Video features the X & M regaining its upright position fine, if the ballast is filled.
tangentair
Post by tangentair »
My :macm: on the few (well maybe several more) times I have had the rail headed for green water has turned up into the wind in spite of my best efforts to do something stupid and ended up stalled in irons. Sorry can't help
empet
Post by empet »
Thank you, tangentair - i'll dare a little more lean next sail time........just got too close to the crew's tolerance the last time...
Hardcrab
Post by Hardcrab »
empret,
Install one of those "incline meters". A search will find all you will need.
The best $25 mod for "creature comfort" out there.
You can peg the meter at 45 degrees of heel with out any fear of going over.
The Admiral was fine once she accepted the real heel angle versus what it felt like to her. She only glances at it when we exceed 35-40 now.
As tangentair mentions, the boat will round up well before you get anywhere close to going over.
Lobo de Mar
Location: Santa Rosa, CA (Sail out of Loch Lomond Marina, San Rafael)
40 degrees
Post by Lobo de Mar »
Had my M at about 40 degrees in the San Francisco Bay with full sails at about 28 mile an hour winds....I know...way too much sail up...but we unexpectedly came from California City and crossed into the shoot! The M handled great and righted soon after we decreased the sail... :macm:
Tony D-26X_SusieQ
Post by Tony D-26X_SusieQ »
If you heel over more than 55* she will lay down. The hard part is getting that much heel without rounding up. :|
Should you mannage to lay her down just grab a line and tie it to the winch then lower yourself down onto the end of the centerboard and walk towards the boat and back into the cockpit as she slowly comes back up. 8) 8) 8)
RickJ
Sailboat: MacGregor 19
Post by RickJ »
Tony D-26X_SusieQ wrote:Should you mannage to lay her down just grab a line and tie it to the winch then lower yourself down onto the end of the centerboard and walk towards the boat and back into the cockpit as she slowly comes back up. 8) 8) 8)
So you've done this then (in a Mac I mean, not a dinghy) :D
Boblee
Post by Boblee »
Hardcrab the inclinometer didn't work for me, the wife watches it like a hawk and starts glaring as soon as it approaches 15 deg, when we hit 20 and everything slides off the table, lookout.
LOUIS B HOLUB
Tony D-26X_SusieQ wrote:If you heel over more than 55* she will lay down. The hard part is getting that much heel without rounding up. :|
I hope never to experience a capsize, or "knock down" - but your solution good to know just in case.
But, I thought the Mac would simply "upright" on its own--just loosen the boom so the sail will empty the water. Im wondering, is this another possible option, especially if or when the water is rough ?
Duane Dunn, Allegro
Post by Duane Dunn, Allegro »
Remember, the rounding up is only a behavior that happens if you have maintained the standard factory mast rake. If you have adjusted your rig to a more vertical position the boat will not round up. Go to far forward and you r boat will actually turn away from the wind in a puf rather than into the wind.
It's just like steering a windsurfer which has no rudder. Instead you steer by shifting the center of effort in the sail. Tilt the mast forward to turn away from the wind and tilt the mast aft to turn into the wind.
Moe
Post by Moe »
Duane Dunn, Allegro wrote:Remember, the rounding up is only a behavior that happens if you have maintained the standard factory mast rake. If you have adjusted your rig to a more vertical position the boat will not round up.
I will testify to that. I tried one day to show Barb it would round up if it got too far over. It did not. Instead we chugged merrily across the lake holding 45º+ and I felt like I could take it over a little further, but didn't.
Tony D-26X_SusieQ
RickJ wrote:So you've done this then (in a Mac I mean, not a dinghy) :D
I admit that I have not tried it. The technique is outlined in Jeff Stag's videos and he quotes Captain Jim of A-1 Sailboats in Mayo, MD. I personaly know Capt. Jim and if he says it can be done then it can be done. You need to go out onto the centerboard to overcome the weight of the water on the sails. 8)
Trouts Dream
Post by Trouts Dream »
And a big warning
Don't try this with a full head.
Never mind the rest of the stuff all over down below.
zuma hans 1
Post by zuma hans 1 »
Knocked flat twice ... both times on Lake Mead, once with ballast, once without.
In both cases she selfrighted as soon as the whirlywinds passed.
[/list]
