Notes to Self - New Owner Things to Remember
- daydreamerbob
- Location: 2008 26M, Yamaha T60, Lake Allatoona - Acworth, GA, Very Much Faster Blue Hull - No Scratches
1) The Forestay Holds the Mast up. The first step to lowering the mast is attach the mast raising gear - not decouple the forestay.
2) Placing a 26X8 vessel in a 26X10 area with wind wake and wave results in scratches and frustration. Sailers drink rum for a reason.
3) Driving around a lake for the first time with no understanding of lights and buoys and rights of way is scary
4) Assembly of anything underway is foolish and will result in lost parts and tools.
- MARK PASSMORE
- Location: Lake Lanier GA - 07 MAC 26M YAMAHA T60 "faster blue hull"
- pokerrick1
- Sailboat: Venture 23
Genoa
6. The genoa ALSO HOLDS THE MAST UP AND KEEPS IT FROM FALLING BACKWARDS
Trust me
(I used to not know this 2 1/2 years ago)
Fortunately I was at the dock when it happened and MANY came to my rescue and we had no damage, The reason it happened is that the idiiot boat hauler and bottom painter (who SHOULD have known better) put the furler on BACKWARDS so that the slot was facing forward.
I, of course, being the astute sailing observer I was at the time, saw this and disconnected the genoa at the furler to turn the furler around, and the rest, as they say, is history
Rick
Rick
- dennisneal
- pokerrick1
Rudders
That's a good one Dennis - - - did you really forget to do that - - - was hard to lower the rudders - - Huhdennisneal wrote: Do not forget to take out the steel bolts that lock the rudders upright before putting the boat in the water.
Rick
- dennisneal
- dennisneal
Boblee
Connect the motor to the steering linkage before launching on windy days with lots of dead trees around as they damage the rub rail (first launch).
Don't rely on wind or currents staying the same right through the night when anchored.
Don't think the Mac will swing (on anchor) the same as other nearby boats or even other Macs.
Don't rely on other boats being securely anchored.
- bubba
Stearing in marinas I usually let the dagger board down 2 ft at least and have the motor and rutters connected with the stearing. Remember when you bring the motor up to disconnect it from the stearing first or you will scratch the motor and the stearing is very difficult, the motor wants to fall to one side or the other. When you need to motor with sails up keep the motor disclnnected from stearing, the boat will stear with a little foward motion. Carry no less than 3 anchors for safety.
- daydreamerbob
- TAW02
- Location: Central Florida 2007 M #MACM1869F707 s/v 'Insagal'
Vent Stopper Pluggy
Oh yeah Bob,
Had the same thing happen here with the stopper plug. Seemed it was too small for the hole too. Even after snapping the lever down it could easily be lifted out of the hole.
Discovered that the plug was adjustable in its static position (open(lever-UP)). Mine could be adjusted by twisting the metal top or hood where the latch is while gripping the rubber part. Some require a small wrench or pliers to hold a small nut on the bottom-side of the plug while you twist.
Ah, so much to learn.
Big T
Big T
- tangentair
