1. Agree wholeheartedly! But don't stand under a tree when you reach shore?? exactly where is safe harbor?Catigale wrote: ... 3 minutes from a beachable shore where I can watch the fireworks from a safe place...ill worry about the boat later.
... My first and closest experience with lightning was as a youth on a soccer field - I saw a bolt come down and hit the goalpost, then travel vertically back up to a lightstand on the staidum some 1/4 mile away, then sideways to a building several hundred feet away....
... a clever trick - we circled a large buoy in the river during a squall(visibility < 75 feet) ...
2. Agree again! Your story reinforces the seeming. Trying to channel lightning is akin to steering a hurricane? ... and a battery cable dangling in the water seems pathetic, indeed. If a mast is so prominent on the water, seems the lightning should just blast straight thru the hull. Casey says the grounding prevents side spikes. Hmmm
3. Clever indeed. That's one to keep filed for the fogbanks that sweep over SF Bay. In truth though, SF fog is predictable, just like your NY lightning ... getting caught in SF fog means you goofed.
