Increased performance with transom wedges ??????
Hardcrab
Post by Hardcrab »
I searched the archives about the transom wedges install. Several folks had posted, but performance gains were not available.
Has anyone come to any firm and final conclusions about any gain/loss/neutral effects?
For now, my best trim for max speed is full down and that nagging question remains, could more down be better yet?
I sure would like to trim to far down, and then trim back up to find the best.
The installation job seems simple enough.
Thanks for your replies.
Night Sailor
Post by Night Sailor »
Hardcrab I was one of those inquiring about them, and deciding after getting several positive responses, including one video segment, to install them. I have them installed but will not launch the boat for a couple of months yet as I'm in the middle of doing many other mods at home in my driveway and cold weather is not my favorite time to do WOT tests anyway. I'll see if I can find whether I saved or bookmarked that video, but in any case when I do test I'll sure share the results with everyone.
Duane Dunn, Allegro
Post by Duane Dunn, Allegro »
Word I got from Todd at BWY was that installing wegdes on an M gave them a 1-1/2 mph increase with the standard Suzuki 70 they install.
I'm about to install a Tohatsu 70 on my X, and Todd indicated he didn't think wedges would make a difference.
The M has less transom angle than a X does.
delevi
Post by delevi »
Geoff (Beene) has transom wedges on his :macm: and is very happy with the performance. Try sending him a PM. Though, knowing G, he'll be chiming in soon enough.
Leon
Don T
Post by Don T »
Hello,
My best performance is obtained with the motor running almost perpendicular to water flow. Lowering the motor drops the bow some but fuel consumption increases and speed slows slightly. I raise the motor until I hear it just begin to cavitate in the troughs then I lower it 2 pulses of the trim button. Having the movable ballast go forward improves everything and requires re-trimming the motor.
vkmaynard
Post by vkmaynard »
We put them on our X with a Honda 50 and a 4 blade prop last year. I actually have to trim the engine up some (= overriding the wedges) to get to it unload. There is maybe a 1/2 MPH increase.
Victor
Yes I have the wedges and am very glad I do. Why? Because with them, I am able to see where I am going while sitting in the seat behind the wheel. Nice eh? Also, I can tell you this, at WOT, fully trimmed in, the boat is nicely on plane, and zipping along, trim up, even a bit, spray pattern changes markedly, speed drops, start to lose horizon over the bow..... all bad things.
Do as you wish with your own boat.
shehzad
Post by shehzad »
Could any one please tell me, why do actually we need wedges ?
Is it for the enforcement of the transom.
The transom of an M does not have enough angle for the outboard to trim in enough. Making it hard to plane out and keep the bow down enough for you to be above to see over while sitting down.
If you need more information, just google "transom wedges".
Like the ones found ......
HERE
or....
HERE
These transom wedges fit all standard 4-bolt pattern engines. Bolt-on engines with factory installed tilt and trim. Cast aluminum construction allows for full, positive contact between engine bracket and transom. Adds 5 degrees of tuck to transom angle.
Gazmn
Post by Gazmn »
Does an :macx: need, or could it also benefit from the wedges?
-Curious
-Gaz
