Question: do you mix the B-12 with gas, or just run the B-12 straight? (sorryTimm Miller wrote:Keep it simple to start out...........get yourself two cans of B-12 from Walmart.......add them to one tank........run the motor up and down the rpm range until the tank is empty......should clear it up. The pick up tubes in the bowls are super tiny and only takes a small amount of gunk to clog them up. I wen through this after one season of the boat in a slip, gas went bad after a while and mine acted the same way. I was ready to tear down the carbs and this was recommended..........cleared up after one tank........give it a shot before you go looking for other problems.
if that's a stupid question
If you mix it with gas, at what ratio?
