Bedding
- David Clarke
- Location: Stafford, Virginia "Freedom" 2003 26M Hull #033 Honda BF50
On our 03M we would experience bottoming out on the original foam. We tried a memory foam insert and it was comfortable, however it resulted in a slightly smaller sleeping area than the original Mac patterns. We then decided to order up another set of rear foam from the factory and, for us, it was the right move. We have also slept on the single berths and they are fine, but as stated here, it's best to cover them. In the end it is really all in what you like. Good Luck
- pokerrick1
- Sailboat: Venture 23
Same same
David did what I did! - - -and it was cheap!David Clarke wrote:On our 03M we would experience bottoming out on the original foam. We tried a memory foam insert and it was comfortable, however it resulted in a slightly smaller sleeping area than the original Mac patterns. We then decided to order up another set of rear foam from the factory and, for us, it was the right move.
Rick
- bastonjock
- pokerrick1
johnnyonspot
johnnyonspot
That's a great idea.Doctor Z wrote:Got a memory foam mattress from Costco and so far it works great in the aft berth. Much better than the original foam, which remains in place under the mattress.
On our old boat, we used to an "egg crate" mattress pad. It helped a lot, but wasn't quite thick enough.
Some day, sailboat builders will be forced to sleep on the boats they make until they choose to install quality mattresses.
- Divecoz
I think for the money I would rather build what I want and or what I will be willing to live with.RussMT wrote:That's a great idea.Doctor Z wrote:Got a memory foam mattress from Costco and so far it works great in the aft berth. Much better than the original foam, which remains in place under the mattress.
For us the aft berth is a done deal , nothing down there that cannot be reached from the battery hatch/cover. But that might not be desirable to all.
